dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I changed the leaking valve cover gasket, changed oil and tested the engine. It ran fine. Then I decided to make a video of the engine running and turned on the engine but forgot to turn the water back on. The engine run without water input for about 10-12 secs. I realized my mistake turned the engine off and then tried it again with the running water. Looks like it was running ok, but Im still afraid that I damaged the impeller. It is brand new impeller I just put it in about a month ago, so it probably should be ok, but... Is there any way to check it without removing and disassembling the outdrive? I ran the engine with the water through the earmuffs for about 3-5 minutes and the temp was stable, was not rising above 150F, as usually.
Thank you.
Thank you.
