I've been having issues cold starting my 150 and restarting it after turning it off when moving from one fishing location to another.
To initally start a cold motor, according to the manual, I have to pump up the bulb, place the throttle in the forward position till it clicks then push the key in to activate the choke and turn it to the right to turn the engine over. This never works, not even after doing it several times. To start it I do all the above but push the throttle 3/4 the way full and turn it over. Most times it will kick off but I have to quickly push back the throttle to avoid racing the engine. Sometimes when I do this "pull back" the engine stalls and I have to start all over again...frustrating!
Once the engine is running and I drive it to a location, turn it off then start it up again, I have to go through the same procedure. You would think a warm engine would start just by turning the key with the throttle in upright neutral postion or at worse in the forward cold start position?
Generally it idles ok once started, but sometimes stalls when placed in gear. To me it seems to idle a little too slowly.
When you drive it along, giving it gas it runs like a champ...I get 52mph out of it with no issues and no trouble going fast or slowing down.
WHAT COULD BE THE TROUBLE?
thanks for you help...
Andy
Andy
