start engine on ground
finer things
I am swapping motors had to change oil pans and many other components I would like to start on ground before reinstall to check for leaks ,need pointers on where to connect wires and do initial startup I know where gas goes and water goes just not sure about electrical connections any help woud be great thank u
dubs283
Re: start engine on ground
battery (-) to ground
battery (+) to starter
12 volts (+) to (+) side of coil
jump slave solenoid (yel/red wire small post) with 12 v (+)
VROOM!!!
VROOM!!!
To shut it off disconnect the jumper from battery (+) to (+) side of coil. ;)
