Starcraft PM 180 - 1988 Max Hp
Jim15
I have an 18' Starcraft (PM 180) that I am looking to upgrade the motor. The name plate on the boat states the max horsepower is 60 hp, and that is the current motor size, but seems under powered and a little small for an 18' boat. I have read that the max horsepower is 115 hp. I'm looking to go up to a 90 hp motor. Does anyone have an idea on the max horsepower rating.
Thanks for the help.
JB
Re: Starcraft PM 180 - 1988 Max Hp
Howdy, Jim.
Welcome to iboats. :)
What do you not understand about the rating plate? 60HP is the maximum safe HP.
ezmobee
Do you have any pics of the boat? I agree, that rating sounds WAY low. An 18' should be rated somewhere between 120-150. However, if it's a real shallow model, I could see the low rating.
JB
Well, I take it back. I agree that an 18' planing hull is usually rated from around 115 to as much as 150.
My problem is the rating plate. Is the boat a tiller steer model? They are always rated much lower. . like half. . .the remote steer models of the same hull.
We need more info, Jim. Got pix??
Jim15
I have done a little more investigation on this, and I originally questioned this because it was difficult to read the rating plate because it has faded over the years. But after cleaning the plate better I was able to verify that the name plate did indeed have a 60hp rating. Currently there is a remote steering console, but the boat was originally a tiller.
So, basically this is the case the JB discribed above, for this boat being that was oringally a tiller the max horsepower is 60hp and if the boat had a steering console when built the rating plate would read 115hp max.
Thanks for the help guys,
Bob_VT
Well since Starcraft IS in business.......... I would suggest you contact them directly. If the hull was built w/o a console then yes the HP rating will be lower then with a console.
