Re: Starcraft 191 SFM with 4,3L what prop
You can use your present wot rpm and gps speed to help tell what prop might be best.
Tell us your present performance and we can help you select the right prop.
It's critical for any boat to be propped for a max wot rpm within its max rated rpm.
very likely your 19" is close to what you need.
Sometimes a specific prop size and style may be needed.For instance a Family wanting to ski with a boat load of people
would require a different prop than say a young couple that runs fast with a little cruising thrown in.
Prop selection is not usually effective for controlling trolling speed.
Increasing pitch will reduce rpm and power, the speed results would depend on the previous prop and performance.
Decreasing pitch increases rpm and power actual results would depend on that of the previous prop.
