Clark in Michigan
- Sep 12, 2010
- 13
I recently purchased a 1979 Tiara 2000 it has a Mercruiser 898 and the starboard exhaust elbows gets much hotter than the port side. I first noticed it when I had to replace the exhaust bellow that attaches to it. Shortly after I replaced it, it cracked again. I just replaced it again but I am hesitant to take it out because that side still gets much hotter than the other.
The last time I had it apart I also removed the thermostat housing. There was no thermostat. Cleaned everything up and put it back together with the thermostat thinking the thermostat was the problem. While I had it apart I also tried to clean the inside of the exhaust elbow.
I pushed water into the elbow intake with the garden hose while it was apart. The water only came out at the back side of the double walled pipe. Is this normal? Or should it have come out all the way around the double walled pipe? I have tried to find a cut sheet of the elbow to see where the water should be flowing but no luck.
Can anyone help?
Thanks
Can anyone help?
Thanks
