I have a Glastron 249 2002 with a volvo pent 5.7 Gi-B
When I go out it's hard to get on plane and stalls when I go into neutral intermittently
I bought the boat in March and it had sat for a while.
I tuned up the boat, plugs, rotor, cap, and filters.
Still stalls when going into netural intermittently, then it's hard to start back up unless I put the throttle up then runs rough.
I connected a pressure gauge to the low side of fuel pump about 18psi when running
On the high side it's a mpi so the connector is on the fuel rail it's 52psi with the key on and over100 $psi with engine on.
Not sure what my next step is,
