steve forsythe
- Nov 7, 2001
- 245
My Merc 200 carbed starts, runs, and generally performs like a champ....except...<br />If i give it throttle very slowly it will slowly increase rpm's until approximately 2500-3000, at that rpm range it will bog down and stall if you dont either cut the throttle back OR floor it. If you give it a quick burst of gas, she will jump right into action. It seems there is just a problem if you baby it at mid throttle. Any ideas???? Fuel filter is new, water separator working fine, new fuel. The engine has always done this. You can 'work' around it by just not babying her, but i think there has to be a way to solve the problem. Also, new primer bulb. Thank you.
