i am working on a 1996 9.9 rude.it went to a dealer for no water out the pee hole,they replaced the impeller and two other parts that i only have the # for 432453 and 386084.<br />the engine ran well before and now it will not idle. i found spark jumping from power pac to ground,wrong spark plugs in it and no water out pee hole. i installed new plugs. power pac and cleaned out seaweed from the pickup. it runs better and has a good stream but still will not idle.i rebuilt the carb and still will not idle.<br />i can get it to idle by choking off carb with my hand but not by spraying mixed fuel in carb through a windex bottle.<br />ok am i missing something in the rebuilding of the carb?
