Stalling when reversing - Yamaha Malta
Chris Beeson
I have a Yamaha Malta 2-stroke 4HP OB, from around 1985. It doesn't have a reverse gear, so I go astern by spinning it through 180 degrees. In this configuration, it has a tendency to stall at moderate reves, usually when I'm in a tricky situation such as backing out of a berth! This doesn't seem to happen when moving forwards; and generally the motor is very reliable. Can anyone suggest a reason for this, or how I might avoid it happening? Thanks!
whofan
Re: Stalling when reversing - Yamaha Malta
When you turn the motor around you may be kinking the fuel line and starving the engine?
Mod2
Moving to Suzuki/Yamaha forum.
