I've got a Envinrude 55HP 1979 two stroke engine with an ongoing stalling problem. <br /><br />My engine is fine and runs great in all gears and full speed when COLD. When the egine warms up though and I make my way back to the ramp back from a fishing trip these are my symptoms:<br /><br />1. In gear doing about 5 knots, I am able to drive the boat through a marine channel which is about 150 meters long back to the ramp. Don't have a problem at this stage, even though egine is in gear at low speed. I have to do 5 knots, otherwise I'll get booked!<br /><br />2. I park the boat and switch the engine off while I go get the car and trailer.<br /><br />3. Back the car up, go back to the boat and start her up. Engine starts up fine, but when put into gear, stalls. Stalls in reverse too. This does not happen when engine is cold. <br /><br />If the engine is left running whilst I go grab the car, it seems to run quite rough, in gear, but doesn't stall as much. I can get boat back onto the trailer with 1 or 2 restarts, rather than 15!<br /><br />A few people recommend rebuilding the carbs, but wouldn't this problem occur when the engine is cold too if it was fouled carbs? Ie. Why is it ok cold, but not hot?<br /><br />Regards,<br /><br />JohnM
