Re: stalling merc
Most likely a fuel related problem. Check all the basics...make sure the fuel is new/clean/no water in it ect. Make certain fuel supply hose is clear...not pinched or restricted. Check any/all fuel filters...Geez, the list goes on. Have you tried pumping the primer bulb when the engine begins to hesitate and stall under a load? Try it...see if it helps it run. If so, then you know you aren't getting enough fuel. The problem might be with the carbs...or the fuel pump. 12 footer will say it might even be a ski rope wrapped around the prop! Hey, it could happen!<br /><br />Try these things...let us know what happens.<br /><br />Walt
