Stalling in neutral when starting engine
Mowczarek
Recently went to start my 2004 mercruiser 5.0 mpi, and it will start then immediately stall out. It will start and run with neutral throttle. Yesterday I changed IAC and that did not fix the issue. Any suggestions on where to look next.
alldodge
Howdy
Sometimes ya just need to give folks time to find your first thread. Last responded yesterday evening, so folks might have been going to bed
https://forums.iboats.com/forum/eng...oard-engines-outdrives/10884923-neutral-stall
Happen to have a serial number?
In your first thread you said after replacing the IAC and letting it run for 15 minutes it was fine, has this changed ?
Is this a new to you boat?
What was the part number of the IAC and where did you get it?
