SS160 and Kicker Motor?
Northwoodsbound
Hi. I have a 1990 SS-160 with a 60 hp Merc, and I would like to use it on a lake with a 10 hp restriction. Has anybody added a 10 hp kicker to an SS-160? Any tips? Thanks.
Here is a picture:
Northwoodsbound
Re: SS160 and Kicker Motor?
Unfortunately, there is a swim platform on the port side....
ezmobee
Ha! I had the same situation. So what I did was I used that same steering rod I linked to earlier, and drilled a hole in the AV plate on each motor and connected them up. That will work fine for your purposes. It would just be a pain to connect them up out on the water. If you do it at home you'll be fine.
Northwoodsbound
Thanks for the great help. I will give this a shot over the winter and post an update.
Do you have a picture of your setup?
ezmobee
Nope. Sold the boat. I'm currently redoing my "new" 18' and will be taking the opportunity to move the swim platform to the other side. :)
