Re: sputter at high speed
If you haven't already done so, do a compression check.
You can verify if the fuel pump is working the way it should by squeezing the primer bulb to see if that temporarily fixes the problem. If it does, then you probably have a fuel supply problem. Things to check would be fuel pump diaphragm, plugged fuel filter, make sure the gas tank vent is open.
If squeezing the primer bulb has no affect, check for loose bolts or air leaks around the carburetor adapter plate, make sure the gasket is in good shape. Sometimes the bolts holding the adapter plate to the block work loose and cause an air leak. Make sure the by-pass port gaskets aren't leaking, and the 4 bolts that hold them in place are tight. Check for any vacuum leaks on any of the hoses for the fuel recirculation system, and going to the fuel pump itself.
