Re: Spun prop
Ayuh,..........
A short piece of 2X4,....
A 1, 1/16" socket,.....
And a Screwdriver to pry the Tabs Up,......
Are the necessary Tools to have.....
Once the little lockng tabs are pried up,.......
Slip the 2X4 between the Prop,+ the Drive,+ turn the Nut CCW.......
Remove ALL of the prop's parts, til there's Only the Shaft.........
Slather Everything with Grease,+ install the new Prop,+ All it's parts........
Torque the Big Nut, CW to about 50ft.lbs.......That's Leaning on the wrench Pretty Good.......
Now,......... Go Boating...............
