Spun Prop or worse? & stuck L.U.
We spun the prop on the stbd. Yam 225 OX66 last fall.
Re-hubbed it last month. Spun it again 22 miles out.
Mechanic says it might be a clogged water passage near the hub, overheating the shaft and causing the slippage.
Might be a problem to fix that, though, the splines have stuck the LU into the Powerhead.
Thanks, have been reading iboats for a long while.
Mark Charlton
