Re: springtime outboard use
I don't agree.
There are two different processes when you say "winterize." One is to protect from freeze damage--that's the draining part, which is nothing to an OB. I hardly call it "winterizing"; it's simply a storage process. Neither is checking for water in the LU--which shouldn't be there in the first place, and won't get in from occassional use unless you have a problem that needs fixing. it can and should be done regardless of "winter" although checking in the fall where freezing weather may follow is wise.
The second is a function of storage. Fogging, treating fuel, etc., has little if anything to do with winter. If you only used yuor boat duck hunting, you'd do it for the summer. If you use the boat every couple of months, it's unnecessary.
And I don't know about the rest of you, but I have only found water in a LU once, in many years and many motors. That was one I just bought used so it "came that way" and needed to be re-sealed. And I believe it sat outside for several winters like that, with frequent, but not constant, freezing temps. Not saying you sholdn't check, but you shouldn't expect to find water, either.
