kbait
- Nov 13, 2007
- 2,481
'72 9.5 evinrude. Spark is fine, ran well, but coughed at idle (couldn't adjust it 'rich' enough on low speed setting). I assumed it was the low speed o-ring (packing) and replaced.. same symptoms. I just put in a carb kit (and replaced 0-ring again) and it runs the same. I soaked the carb in Amsoil powerfoam, and blew out all orifices...
If I choke it most of the way, it will idle quite nicely, and when I stop choking it, it will idle for just a bit, and do the 'lean' cough no matter how rich I set the needle. Could the carb still be clogged somewhere? It looked like new when I took it apart, and nothing seemed clogged by blowing air through it. It really acts like the low speed jet packing is leaking air, but I cannot see how, after twice replacing that o-ring. The needle looks fine w/o any grooves.. Any ideas would be appreciated. Also. It will stall out when low speed jet gets close to seated, and coughs even if turned out 3 turns (obviously wrong!)
