georgeJeff
- Oct 18, 2013
- 28
Can anyone tell me exactly where the float bowl vent is located? I have an open hole just under the carb throat (where the choke is located). Is that it? I thought it was one of those holes that was supposed to be plugged with lead shot, if this is the float bowl vent, I have some undoing to do. Thanks. Motor is hard to start, doesn't idle well, dies when put in gear under load. Will stay running in reverse though, and the bulb never really gets hard regardless of how many times you pump it.
New carb kit, points, condensers, coils, head gasket, manifold gaskets, water pump. Motor will be at the bottom of Cumberland river soon without the least hesitation, eqivacation, or mental reaervation. I'll post GPS coordinents and tape a 9 cents to it so your efforts won't be in vain.
