basilfaulty
- Jun 15, 2011
- 7
I have a 1994 Bayliner Reflexx with a SJ90. Boat starts and runs, idles fine no hesitation when throttling up. Seems to me that it isn't getting full RPM. Here is what I have so far: Red Stator 696 ohms, CDI electronics switchbox, new regulator (Mercury), trigger White wire 1264 ohms, purple 1148, brown 1173. No rev limiter. Replaced carbs with a set of used matching carbs cleaned and adjusted. Throttle plates fully opening. Initial and full timing checked and adjusted. Compression on all 3 cylinders around 120 +-3 or 4 psi. Reverse gate is adjusted properly. New, not reconditioned (Mercury) Impeller, wear ring is in good shape, almost zero clearance to new impeller. Ride plate is sealed and undamaged, intake grate is undamaged. The boat is difficult to plane and will run only 27 or 28 mph on the speedo 2 people 1/2 tank of fule no other load (cooler boxes, etc.) I am at my wits end with this thing, don't know what else it could be. Almost forgot, new diaphragm in the fuel pump as well.
