wavecutter9916
- Aug 18, 2010
- 6
Hello, I am new to the site. I just recently purchase a 1997 Wave Cutter 13ft jet boat. The first time we started the boat it would just flood out. I cleaned the carbs and rebuilt them with carb kits. Put it in the water and it would run fine at idle and get up on plane fast but then would bog. RPM?s would go up to 6000 full throttle for ten second the drop down to 4000 then it would bog or stall. It was like it was not getting fuel. Once the carb bowls fill back up it would do the same thing. If I put my hand over the lower carb for a second while moving the RPM?s would go back up.
I am guessing it needs the fuel pump rebuilt
Took the carbs off and checked the reeds. Two of the reed were bad so I replaced them. But still getting the same response.
Also checked the electrical system, Everything looked spark on all 4 cylinders new plugs ect?.
Any help would be great!
