Guys,
My Sport Jet 120 is running very rich at warm idle.
Rebuilt carbs, fuel pump, new/tight lines, etc. Good compression. Idle mixture on carbs out 1 and 1/5 turns each, plates and cam aligned.
Ohm'd the auto enrichner today and got a reading of 28. Manual says between 18 and 20 I believe.
Took it off the boat. Applied power to it to warm up, needle seemed to move. Ohm'd warm at only 24. Manual says when its warm it should be approaching infinity.
I blew in it and the few times I tried, even though the needle moved only once did it seem to effectively block my air.
Should I assume there's an issue simply do to the failed ohm test even though I can make the needle move (albeit not with the needle seat housing on)?
I'm suspecting this is my rich issue, still allowing fuel to blow by.
Thoughts?
Thanks,
Frank
Thoughts?
Thanks,
Frank
