1994 Regal Jet boat with 90hp Force Mercury engine. The voltage regulator burnt, magnets loose and damaged stator. Im replacing the stator and voltage regulator with a used flywheel. Not sure how to connect the wires correctly.
Re: Sport Jet 90HP Force Mercury Electrical Diagram needed.
I got all the electricals hooked up correctly. My wirings are the same as in these diagram. It probably because previous owner did a conversion ? not sure but I do have the CDI
But now I got to wait for a new ignition / key in the mail since I lost my keys somewhere.
The only difference for a red stator is the green/white and white/ green wires from the stator goes to a candybar sized adapter that has blue wire that goes to the cdi and the red wire is not used on the cdi
