Sorry guys but this is going to be a long one. I have a 94 Sportjet 90 with the threaded impeller shaft. I wanted to replace the impeller and wear ring but I wanted the solas impeller, so I bought the splined shaft to match the splined impeller that solas makes. (my dealer said this would be no problem) Problem #1 The drive gear that goes on the end is a different spline, I need to replace that gear. Do I also need to replace the one in the case? the splines are different on the shaft but is the gear pattern different? #2 the bearing that I have bought does not fit the shaft, merc says it is the right part. bearing #30-820292 does not fit on shaft 44-820505. The shaft needs to be machined down .020in. I am about ready to thrw this mess away and forget about it. Any help would be appreciated. The wear ring I had machined out by jetco and a new stainless one put in. I think it should be a pretty decent set up if I can just get the damn thing back together.
