Kend301 and other boat brainiacs,
Admired your dogged diagnosis of Chronomania's problem. Could you possibly lend me some help?
I have a 94 sport jet 90 in the 33000 serial number range. Same problem as usual: no spark. It ran fine when I parked it in 2004, but now it cranks but won't start.
It has the red stator and newer voltage regulator. Disconnected the yellow/blk wire-no spark. Disconnected the two yellow (voltage regulator-854515 1887 printed on case) wires-no spark. Disconnected all wires to the rev limiter (821889 A6 printed on case)-no-spark
Read some of Kend301s earlier posts and checked what I could:
Stator (green/white to white/green) 685 Ohms
Triggers each in the 1210-1250 Ohm range
Coil primaries .5 ohm each.
Voltage through the 5 amp fuse to the various black boxes.
Is there a way to test the switchbox thingy (xx2-7778A10 0963 printed on case) ?
Haven't pulled the flywheel, but I guess that is next.
Help!
Help!
