Sport Jet 120 Problems (Go Figure)
polebarn
I have a 1995 Baja Blast with a Force Jet 120. First of all my Ride Plate seems to be bent in the front. How can this be repaired without buying new. I also need to trobleshoot the engine not wanting to run.
Please Help me someone.
jerryjerry05
Re: Sport Jet 120 Problems (Go Figure)
Do a compression/spark test.Check the fuel pump filter and diaphram.What's a ride plate?Post a pic.The section for PWC has a guy calls himself kend301 he's up on this stuff.The motor is a Force 120 powerhead(I believe).Simple diagnostics are the same.
Ethanol is messing up a lot of motors.It's delaminating the inside of older hoses causing clogs in the carbs and fuel filter.Check for soft hoses and junk in the filter on the motor.Check the diaphram.
Do the tests and post your results.J
