sport jet 120 losing Fire
wolfman014
I have a F16 searayder I picked up a little over a year ago. After carb rebuilds it runs great but now after 20 mins of run time I loose all spark. Let it sit for a week and it miraculously regains fire......15 mins into running....loose fire again.....would the cdi be the only culprit of this?
kend301
Re: sport jet 120 losing Fire
Post up year , HP and serial number of engine . Lots of tests we can do to isolate the problem . Also see the first post in this forum "Sport Jet Basics" and test what you can , Post results. If you have a 120 with a CDM ignition only do the first 4 tests and then only ohm the stator , the rest does not apply .
wolfman014
Thanks Kend301, It is a sportjet 120, 1995 model Engine Ser# OE134412. Also Im curious as to what the inline gellback component/adapter is that is inline of the green and green/white wire from the RED stator and comes out Blue and blue/white on the side to the CDI. Seems like all schematics leave this off. Is there a way to check this? all magnets appear to be in good order as well on flywheel.
Stator
Green to Green/white 1075
Trigger using white/black as ground
Brown 854
Purple ???:confused:
White ???:confused:
however as per book
purple to white 785
seems my cheap meter let me down if white/black as ground is correct or I found my issue? If all wires are being tested disconnected I assume having the battery out is not affecting me correct? If I am getting nothing on ohms. Will test with a better meter and post results ASAP.
kend301
Woops , sorry on a 120 you ohm the trigger by going from brown to white/black , your reading was good there then ohm the purple to white . Both readings should be between 700 to 1000 Ohms . Your stator reading should be between 500 and 700 ohms , Your stator is toast if you have over 700 ohms . Re check the stator and post results but that looks like it is it .
The extra box is the stator adapter , your boat came with the 9 amp black stator and the 16 amp needs an adapter to work properly
Also be sure you are testing between the box and the stator with the wires disconnected . If the stator is in spec then , unplug the blue wire from the switchbox , plug the stator wires back in and test connected , if readings are then bad again , post up and do not order anything I need to check one thing if this is the result .
wolfman014
ok new battery in the meter makes a difference:D
Stator
Green to Green/white 516
after adapter
Blue to Blue/white 506
kend301
Have you done the wire disconnect tests as outlined in the first post , "sport Jet Basics " ?? If you have and still have no spark , do a switchbox bias test.
1 OHM meter set to dc volts
2 Red meter lead to ground , Black meter lead to the white/black out of the switchbox.
3 Crank engine and post voltage reading .
wolfman014
is it "Sport Jet important info and basics " .....if not can you post the link to "sport Jet Basics" page or tell me how to find the one you are refering to? Thanks Again
kend301
Sport Jet Information and basics is the post i was refering to . I wrote it :)
