Ok... I was in the Bay in NC, and for the first 3 days I ran the boat, it ran fine. Last day it was taken out, was WOT then the power dropped to an idle speed, and any backing off the throttle would result in the engine shutting off. Boat would not restart when I took to lake on way back to clean out the saltwater.
What I've done:
1. Checked for spark (used timing light and got what I would consider a normal light pulse)
2. I cranked and cranked, and logic would dictate that eventually some fuel would dump out the exhaust... but nothing.
3. Took apart the fuel pump, checked diaphragm, screen, gasket. all OK
4. Left outlet hose off the pump and cranked, fuel dumped out of the outlet port.
5. Pulled the bowls and checked for fuel, bowls were full
6. pulled Black / Yellow wire from rev limiter to see if REV limiter was faulty. No difference.
I've had had this engine apart when I bought the thing and have rebuilt everything but the powerhead itself. (only 40 hours on it)
I hooked everything back up and tried again to crank, got nothing... also, just to check if it needed to be primed, squirted a little starter fluid in carbs, but it would not fire. Any help on this matter would be greatly appreciated.
Thanks,
Jason
What I've done:
Thanks,
Jason
