SplitFire Spark Plugs For Force 1995 70 hp motor
joeripp
Does anyone know what SplitFire plugs are for a 1995 70 hp Force motor and do these plugs make a difference or is it just Hype!<br /><br />-Joe
Bob_VT
Re: SplitFire Spark Plugs For Force 1995 70 hp motor
I would suggest you do a search on this board for Splitfire. Read the posts, they have not gotten too many good comments. I suggest you stay with the recommended plugs.<br /><br /><br />Bob ;)
dmessy
Spitfire??Egad!! no way,just hype. A single, fat, blue spark at the right time is all you need.Stick with fresh Champion premanant gap plugs as manufactuer recommends..,
ODDD1
Joe, the only thing splitfires will do is lighten your wallet.... a NGK BUHW surface gap, or perhaps a standard side electrode NGK B9HS-10 [@ .040"] if you are trolling with it...
Rex
NOT HERE I KNOW SOME CARS JUST DONT RUN GOOD <br />ON THEY. I USED THEM ONCE AND NEVER AGAIN.
JeffSlade
ODDD1 is right. Splitfire runs tooooo hot and will burn a piston in time. Believe me I've been there. Use Champion only....
