Problem is, on that model, they moved the o-ring from the drive shaft to an internal groove in the crankshaft---where you can't see it. If it is missing or deteriorated you can't keep grease in the splines very long. Worse, moisture gets in and rusts the splines in the crankshaft. When they rust out, you don't go anywhere. It's your call. Do you care enough to pull the powerhead and check?
