Re: Splicing transducer cable
Basher, I just did that exact thing last week.<br />If the transducer has a temp probe there will be <br />2 wires and a twisted uninsulated wire wrapped in foil, The 2 wires are yellow and white. The other<br />2 wires blue and black are used for the transducer<br />send and receive. They are also wrapped in foil.<br />If you cut them be sure to used heat shrink tubbing and 60/40 solder reconnect them. donot use crimp on connectors. It will work just fine.
