Re: splicing fuel line
hello<br /> if they can both use the same fuel why not? all you need is a three way valve. off, motor 1, or motor 2. its not hard nor expensive. if the fuel is gasoline, make sure the valves are UL rated and coast guard approved for marine gasoline. good luck and keep posting
