Spinnerbait Blades
ChugBug
What spinnerbait blade or blade combos do you use for BASS fishing?I really don't have much luck with them but when I use a spinnerbait it's a Single No.4 or a DOUBLE WILLOW LEAF.
JB
Re: Spinnerbait Blades
Howdy, Bug.<br /><br />Except for musky, I always use a single Colorado blade. Different sizes and weights to reach different depths and to fish for different fish.<br /><br />I have no Ph.D. in bassology, but it is my firm belief that what you cast doesn't matter nearly as much as where you put it.<br /><br />Good luck. :)
sloopy
DItto on JB... is there such thing as Bassolagy?
bKelly
ChugBug,<br />It depends on the situation. When fish are very active almost any spinner combo will work. <br />In the early spring I usualy throw a 1/2 oz with a large colorado (Thumper),Bass in the spring have a low metoblazim rate and usualy wont exert a lot of energy chasing small baits, the 1/2oz also go deeper have a lot of viberation and are easy to slow roll. If the water is clear willow blades work great, they have more flash but less vibration.<br />In the summer I like to use a Colorado/Willow combonation. Early in the morning before the HOT sun bakes everything I use a 1/4oz spinner with a chartuse colorado and a white willow and a chartuse and white skirt. The 1/4oz is easy to run just under the water surface making a bludge in the water. When it heats up I go deeper and look for structure. <br />You can use smaller baits in the summer also and at times the smaller baits work better. When the fishing pressure is high a downsized bait might be the trick.
ChugBug
:) Thanks for some of the tips.Here in EASTERN OHIO we some very tough fishing.I'm going tonight with some co-workers and I know I will be the only that will try a spinnerbait.The best time up here is a 1/2 hour before the sun sets after that you might as well put the spinnerbait back in the tackle box. :)
bKelly
Chugbug,<br />Have you tried using dark colored spinner baits at dark. Black and Red with a large black Colorado blade works well at night. You can also add some rattels to it like the ones on bass jigs. The large colorado blade gives a pulsing viberation that the bass can chase at night. The dark color makes a silhouette against the sky even at night unless it is very dark outside. Try keeping the bait near the top, during the summer bass feed a lot at night because the water temps. begin to drop and the move up to shallower water in search of bait fish. :D
derwood
I like the mepps spinners....The colors depend on your conditions....If you need it, they probly got it....They also work well in saltwater for reds....Gold blade with a chartruce skirt....its a killer.<br /><br />Derwood.
ChugBug
bkelley:tried them all. My only fish came on a SPINNERBAIT last night :D {WHITE/CHAR/NO.3}I used a black/NO.5 COLO.{MY THUMPER} and caught 0. We fished over weed beds,trees,and rocks.Air temp dropped fast after dark 65 to 60.No one caught much last night :( .I'm telling you these lakes are tough.
bKelly
Must be nice to have temps in the 60's. Its been a scourcher here. 90's with 95-98% humidity. :( Have you tryed crankbaits? What are you fishing for Largemouth, Smallmouth, Kentucky(spotted bass).
Allen Henry
I agree with derwood. GOTTA like those mepps.<br /><br />TRP251 :D
bKelly
I used Mepps for years and the local stores quit carring them. It was a safty pin style spinner. I loved those spinners. They were real good. Now I use WarEagle, Hart's, Terminators, and custom made spinners.
ChugBug
BKELLEY:Always bass-smallmouth and largemouth.Saugeye were hitting a week ago but not last night.The hot bait for us now is a NO.11 RAPALA JERKBAIT.We use and try anything.The smallmouth were hitting good before the heat wave.If you could find a map of Ohio look at the <br />east side.You will see Piedmont,Clendenning{The dead sea},Leesville{big muskie lake :eek: },and Tappan Lakes.From lake to lake is about 6 to 8 miles.There is good fish in there but you got to get out there more then once a week and with a family you just can't get out enough.
