This problem is most evident in trolling applications where greater pressure of the line is constantly against the guides.Originally posted by cwilt:<br /> Has anyone ever had a problem with spiderwire cutting line guides? i am changeing rods from an allstar which had ceramic guides to a berkly bionix which has metal guides. had no problem on the allstar. the rod is being retired...
More pressure for a very short period of time...we may troll for 10-16hrs a day chasing wallys...<br />I've used Berkely fireline since it came out, and I'm fishing about every weekend from march to november and I've never had it eat a guide, never had it pop one off either and I use flor. carbon leaders too on trolling rods.<br />I tried it on baitcasters...it doesn't work when fishing timber...it likes to hang in the wood, mono only there. I have found the best application for braids for me to be on jigging rods for lite-bite walleye...you'll have fish on mono that are gone before you know they were there.<br />Now, with all of this said, Fireline IS NOT a braid, it's a Thermal filament line (the fusion of micro dyneema fibers)that does not have the cross-hatch pattern of lines such as Spiderwire-a TRUE braid, which I can see absorbing water in use, collecting dust while still wet, and being abrasive until the dust is agitated from the line...i use 50# line with the drag as tight as it goes. probably more pressure than trolling!!
