speedometer not working
buckhorn237
speedometer works when i blow into it. ran a new tube and installed new pitot hooked back up and it still does not work. please help
Lrider
Re: speedometer not working
might be cheaper to get a gps :p
Stachi
what position do you have the pitot arm in ? should be 90 degrees to the bottom of the hull the ( hole in the end of it pointing towards the bow...)
Stachi
also , is the pitot tube in clear water while you are running....if it is in an area off of the stern ,that is 'white water' while running. it will not function...no compression from air entrained water...
buckhorn237
new pitot arm is in the same spot and position as when the speedo worked thanks for any help could the speedo still be bad even though it registers with air
Stachi
Have you blown into the new tube after installing it...maybe it is kinked or clamped too tightly someplace...
dockwrecker
Stupid things never work for very long or accurately. I gave up on mine. It fills the hole in the dash. (sigh)
buckhorn237
it blows through perfect blown both ways with air compressor and speedo disconected reconnected and still does not work i think ive tried everything
JimS123
If it doesn't work, there is either a blockage in the hose, a leak at one end, or the gage is defective. Pull the connections and seal them again. Blow thru the pitot to be sure it is free.
I'm surprised it works by blowing. Usually takes a lot of pressure. I could never get mine to work that way. Mayby that signals the problem!
JimS123
Simply not true. The gages last almost forever unless they get frozen. The secret is to keep the hose sealed so no water gets in, and of course replace the pitot if it gets broken off.
The weather was absolutely gorgeous today and I did my annual performance check - mph vs. rpm vs. fuel usage. My 26 year old pitot Teleflex speedo was spot on to about 20 mph, and only off 1 mph vs. GPS up to WOT.
Bob_VT
Welcome to iboats!
AIR COMPRESSOR !!!! :eek: Too much pressure!!! Well..... the spedo is probably toast :(
They sell replacements here on iboats in the store.
Lrider
of course there is the possibility that the tube you used to replace the old one is not right for your speedo
buckhorn237
hooked a couple of feet of tube to back of speedo and ran air compressor at 10 to 40 psi speedo registered different speeds with different pressure
dockwrecker
Well then you're welcome to come fix mine then. It's been blown out, re-tubed, re pitoted more times than I can remember, and that's just this boat. Out of the 8 boats I've owned, I can't remember having one that was even close. Consider yourself lucky or me not...
Stachi
disconnect the tube from the guage next time you are out on your boat ..run the boat and see if water is coming out of the tube
buckhorn237
not getting water when tube is disconnected and moving but i can blow water threw from the pitot arm at the dock ran brand new tubing today and it is not kinked it acually has a better path than before
buckhorn237
i have a gps already and the speedo was right on when it worked I just can't stand having something not work and I can't figure out why
jmarty10
This post is too funny..........mine crapped out yesterday. I just downloaded a GPS speddo app from my droid.
Philster
We're talking about a device that operates on 3-7 PSI (I think).
Easy to exceed that limit just by blowing into it! Air compressor = death.
