Re: speedometer not working?
Actually, your speedo should be integrated in your outdrive. There is a small hole, just above the "bullet". These holes get dirt and debris in them. Take a piece of coat hanger, or a small drill bit, and Carefully clean out the hole. Also, there is a plastic fitting, shaped like a cross, that is supposed to be pushed into and turned-to-lock, in the front of the anti-ventilation plate. To see it, tilt the drive all the way up (while boat is on the trailer), and get down under the transom and look at the leading edge of the drive. Hope that helps.
