Re: Speedometer help
There is air in the tube that goes to your speedometer, as the water rushes underneath your boat it tries to enter the tube which compresses the air in it and the pressure moves your speedomoeter. The tubes can plug or get kinked or something might have gotten into the pilot fitting that was shown to you in the previous post. Tubes can also come off the back of the speedometer or be cracked or split Lastly there are times when there is a mechanical failure with the speedometer, however usually it is one of the above issues. Also the pilot fitting should be locked in the lowest position or it will not build up the pressure sufficiently.
Hope this helps.
