Speedometer Connection broken
celstad
I found the speedometer hose from the outboard broke off right where it goes through the transom. Trouble is the connection is behind the outdrive and I can't get a hand in there or even see where it needs to go back on. Is there a way to pull the connection inside the boat and put a new hose on to the outdrive? Looks like a plate of some sort where the hoses and wires go through. It' a 93 Yamaha, 3.0 I/O.
