I bought a 1993 3.0L Mercruiser used about 2 months ago. The speedometer dosen't work. I have learned from this site where the pitot is on the outdrive and it is clear. I unfourtunetly don't have a hose connected to it. I found a small hose sticking out the transom that I have traced out inside the boat heading towards the bow. (Assuming this is the speedometer hose)is there a special fitting that connects the hose to the pitot? The hose sticking out the transom is a lot smaller in diameter then the plasic fitting in the lower unit. I haven't found a good diagram of this part of the outdrive.<br /><br />Thanks,<br /><br />Jeff
