Re: speed sensor, transducer install question
I have a 21 foot runabout and mounted my 8 degree transducer right next to the Pitot.
In fact transducer and pitot tube share the same screw hole.
On the other side of the pitot tube have my 20 degree transducer and it shares a screw hole on
the other side of the pitot tube.
Speed and temp share a screw hole on the other side of the 8 degree transducer.
So on the starboard side from the engine I have a 20 degree transducer, pitot tube, 8 degree transducer,
speed sensor, 24 by 12 trim tab then the chime.
Both the transducer work and never loose bottom signal and the speed sensor is very accurite.
I do under some condition need to reduce the sensitivy some at higher speeds or the screen is mostly black.
My depth finder is a 1985 model long before they came out with auto sensitivy.
Also my hull is a 21 foot modified V Aluminum hull.
One suggestion if you have not drilled any holes and mounted transducer think about a
transducer mounting plate first and then mount transducer to the plate.
This way you do not need to drill holes below the water line or if you use the short plate only need two
holes in the hull then can drill as many transducer mounting holes as you want without ever
drilling another hole in the hull.
Go to
http://www.cabelas.com/
and search for TRANSDUCER MOUNTING PLATE. Then click on it and see both styles.
They sell them here at Iboats but I always have trouble finding them with the search.
