Re: SPDT VS DPDT?
S ingle<br />P ole<br />S ingle <br />T hrow<br /><br />D ual <br />P ole <br />D ual <br />T hrow<br /><br />Throws are the number of conducting, or 'on' positions the switch can be in. Poles are the number of switch circuits. A Dual Pole switch is like pressing two Single Pole switches at the same time.<br /><br />If the switch has a middle position, say "all off", you need a SP3T.<br />If the switch has only two positions, say on (one set of lights) and on (other set of lights) you need a SPDT switch.<br />If the switch has two positions, but only one on position and the other off, you need a SPST switch.<br /><br />Of course, you don't have to use the other poles, or the other throws, so you can use a DPDT switch in a SPST application, or a DPDT switch in a DPST application.<br /><br />So by your description, you need a SPDT switch or better (ie, a DPDT or a 3PDT or a... Just as long as it ends in DT)<br /><br />Clear as mud?<br /><br />SPDT:<br />
<br /><br />DPDT:<br />
<br /><br />SPST:<br />
