I searched forum pretty extensively and couldn't find the answer for this model engine so I was hopping someone would know or be able to reference a manual. The online parts diagram was no help either.
PROBLEM: I removed the spark plug wires and can't remember which wire went where on each side of the engine. It seems logical that the the top right coil wire would go to the top right cylinder, the bottom right coil wire to the bottom right cylinder and the same w/ the other side.. top to the top and bottom to the bottom. But it seems like the top/bottom coil wilre/plug was crossed on the left and not on the right... if that makes any sense. Have carb problems so can't get it to run to test AND it's not my boat so I'm trying to help a family member out. Anyone know which plug wire goes where? Any help would be appreciated.
Thank You!
Rob
Thank You!
Rob
