Troutboy NZ
- Apr 24, 2007
- 32
Gidday from New Zealand! I have a 2005, M40D2 Tohatsu 40hp (under the guise of a Mercury Lightning XR). I am confused as to which sparkplug to run in it. The factory manual that came with the engine says run a BR7HS-10, but the sticker under the engine cowling on the block says to run the BR8HS-10... a colder plug, and as I understand the plug that is recommended for the 50hp Tohatsu, not the 40hp?
Now I know both these engines are the same basically, which should I be running?
Also the mixture screw settings are confusing me. The motor has done approx 50 hours now and the screws were all about 3.5 - 4 turns from seated, this seems too much to me and would explain the slightly oily plugs - it was however still running fine. Can anyone please give me the starting point for the mixture screw settings on this 40hp and what you find is optimum?
Thanks
Thanks
