spark tester
bubbakat
Re: spark tester
Bass cat are those wires fastened to the plugs with JB weld? I am interested in how you fastened the wire to the plug itself before you put the putty on them.
Basscat 1
Re: spark tester
I just bent down the tip of the electrode and looped the wire around. Where the wire goes through the nut that holds the spark plugs, I used a die grinder and ground a small slit in the nut so the wire will go straight out. Then put on RTV to help hold it and seal it off.<br />All together, it took me about 30 mins. to build.
