Spark Problems
ewiens40
I have a 1977 johnson 140 outboard. It only sparks on one side. Can I check the charge coils and sensor coils with a multimeter? If so, what should I look for?
Joe Reeves
Re: Spark Problems
Eric.... If memory serves me right, that model has but one powerpack. The stator/charge coil assy simply provides voltage to the pack as one unit ie... if it causes spark to be on even on one bank, the stator is fine.<br /><br />The sensors.... On the bank that has spark, take a ohm reading on the sensor on that bank. Now, compare that reading with the sensor on the other bank. If they are identical or extremely close, the sensor is fine on both banks. If the readings are vastly different, then it's safe to assume that one sensor is faulty.<br /><br />Let us know what you find.
ewiens40
Re: Spark Problems
Thanks for the help. You are correct, there is only one power pack on this unit. As one side is sparking strongly, your comments suggest that the charge coil is OK.<br /><br />I checked the coil sensors and the sparking side reads 8.1 ohms at the 200 setting while the other side reads 8.3. Based on your comments this suggests that the coil sensor is OK. <br /><br />Am I interpretting your comments correctly? If so, does this mean the problem is the power pack?<br /><br />Any comments are appreciated.
Joe Reeves
Re: Spark Problems
Eric.... Double check the sensor readings first.<br /><br />Meter on low ohms scale. Sensor wires disconnected from pack. Meter connected between sensor leads, should read 8.5 ohms +\- 2 ohms.<br /><br />Meter on high ohms scale. One meter lead to ground, other lead to sensor leads. Any reading at all indicates a faulty sensor.<br /><br />I assume by what you've said that those sensors are okay, but I just wanted to double check (a good practice).<br /><br />If they still check out okay, before buying a powerpack, do this:<br /><br />The coils that aren't firing, remove their leads from the powerpack. Now, the coils that were firing,switch their leads to the non firing coil pack terminals and test for spark.<br /><br />If those previously good firing coils DO NOT fire, the powerpack can be assumed to be bad. However if they DO fire, the pack is okay and both of your original non firing coils are bad (unusual but it happens).<br /><br />Nice to have an engine that comes equipped with test equipment isn't it?<br /><br />Keep me informed.
ewiens40
Re: Spark Problems
Thanks Joe. I checked the sensor wires as you suggested. One side reads 8.0 ohms and the other 8.3. Then I checked each lead with a ground. None of them read anything - i.e.- the meter stayed at 1. When I connected the coils up to the opposite leads, the coils fired on the other side.<br /><br />Based on your comments and what I can read elsewhere, it looks like it is a power pack problem.<br /><br />I will let you know how it turns out. I won't get a new power pack until tomorrow so if something I said here does not seems right, send me a note. Thanks again for your help!<br />Eric
ewiens40
Re: Spark Problems
Disappointed! <br />I replaced the power pack and the motor still only fires on the one side. I went back and rechecked all the measurements you asked and the answers I gave were all correct. Any suggestions about what I should check next? and how to check it?
