Re: spark-plugs
The choice depends on what the spark plug looks like after you've been running. If the porcelin insulator is dark or black, use a hotter plug. B7S is equivalant to a J4C, and the B6S is a little hotter, like a J6C. The hotter plug may give you a better idle, but make sure it doesn't get too hot when running wide open. If the plug is too hot, it will be dry and powdery.<br />Ideally you want a tan colour. To test, run wide open for a minute, and then immediatly kill your engine. Then remove the spark plug and look at the insulator.<br /><br />The difference between a B7S and a B7HS is the HS has a slightly longer threaded section (.462" vs .375"), so the spark plug is stuck further into the engine. I've seen people run them before, so I guess usually the piston doesn't hit them.<br />For some reason, B6S and B7HS seem to be really popular plugs. B7S plugs are really hard to find.<br /><br />Your spark plugs have little to do with overheating or measured compression. If they're too cold, they will foul at low speeds causing a misfire. If they're too hot, you get knocking and piston damage.
