spark plugs (confused)
saintlee
I read these forumes about an hour a day and the more i read about plugs the more confused i get.
Most talk is about the AC Delco MR43T and MR43LTS Marine Spark Plugs.
The original plugs in my engine were AC-41-932. After research I found that they were replaced by the AC-41-993.
then again replaced by AC-41-101 (Iridium)
My engine is a 5.0 gl-e 4012160010
I guess my question is which plug is correct and why.
I want to use the Iridium only if correct and good for marine use.
Thanks in advance for all your help . Past and Present
halfmoa
Ensign
Re: spark plugs (confused)
Well I'm confused too because the AC Delco 41-932 is still in production. Are you saying that the manufacturer has changed the plug to the AC 41-101?
saintlee
reason for post (CONFUSED)
I read that the 41-932 is now replaced by 41-993.
I believe both are platinum
The 41-101 is the Iridium version.
Are these marine plugs? My original plugs still had the red overspray on them from factory (41-932)
Don S
The AC MR43LTS plugs work fine for the carbed engines like you have. The Iridium plugs are used in the MPI engines.
If you were to order the spark plugs directly from Volvo, you would get Champion plugs (Not iridium), which is the worst thing you could do to a marine engine.
True, and they are Iridium plugs.
halfmoa
Ensign
The 41-932 is still in production. The only difference I can find between the two is that the 41-101 plugs have approximately 1/8 inch longer threads and they're iridium. They're both permanently sealed tips with zinc bodies. Does that make them marine grade? IDK for sure but sometimes there's no difference between standard production parts and marine grade.
My opinion is that unless the manufacturer has issued a service bulletin stating to change the plug to a different part number then I'd use the original equipment. The iridium plugs are longer. I've rebuild an engine and had to have the pistons notched to clear the plugs. In a fight of piston VS plug everyone is a loser...especially the owner of the engine!
EDIT: Don posted as I was typing. My unwritten rule of iBoats is that if Don's opinion differs from mine, I'm wrong...
Don S
No, you may be right. It looks like the 41-932 & 993 are now platinum. They used to be iridium, and said so right on the plug and they cost $21 each.
saintlee
So Don
Can i use the 41-101 (amazon $5.65) on a carbed engine
or should i stick to the original 41-932 now 41-993 platinum
or switch to AC MR43LTS ???
What did you mean by this?
"which is the worst thing you could do to a marine engine."
Don S
You got 6 years with the original, and they came from GM, not Volvo.
Volvo only uses their PN, for plugs and in boxes of 4. Since they changed the PN, who knows what's in them now.
Mercruiser uses the MR43LTS in their equivalent year & model carbed engine, and the 41 series in the MPI.
I know nothing about the 101 number or where it came from so will not comment on it ability to do the job.
I really dislike Volvos spark plug specs, or should I say lack of specs. Just a Volvo part number that keeps changing and is not cross referenced to anything.
saintlee
Well after all that I guess I will stick to the original ac 41-932 aka 993
Thank you for clearing that up
My last question on the matter is what plug GAP ???
Thanks Again
halfmoa
Ensign
GM 5.0s gap from .35 to .45 depending on application.
saintlee
The parts chart uploaded fine
but the owners manual failed to upload
end result AC 41-993 Gap .060 for my 5.0 gl-e carbed engine
Thanks to all
saintlee
waited a little longer and it works
thanks
