Spark Plugs Champion J6C vs CJ6, RCJ6, & RCJ6Y interchangablity
cgodfrey
My favorite local hardware store is going out of business. They have piles of Champion CJ6, RCJ6, & RCJ6Y, and some Arnold brand equivalent spark plugs marked way, way down in their lawn and garden clearance section.
I generally use tried and true Champion J6C spark plugs in my menagerie of old OMCs as has been recommended countless times, but the cheapskate in me is intrigued.
Am I mistaken that the CJ6 is has a shorter, stubby profile, but has the same threads, and spark characteristics as a JC6, and they are essentially interchangable? Any reason why the R/Y variants would cause me problems?
Thanks for any insights.
Chris
F_R
Re: Spark Plugs Champion J6C vs CJ6, RCJ6, & RCJ6Y interchangablity
"R" means resistor. Not good
I'm not familar with the "Y" but I think it means extended tip. Not good if it does.
C means chainsaw---as you see it is short and stubby. Might be tapered seat without a gasket, I'm not sure. Boots may not fit, and short insulator is more prone to arcing over if water should get on it.
1946Zephyr
Well, you might be able to tune your yard equipment with all these good deals. :D:D
