I have a 78 235hp evinrude i was idling perfect at 900 in neutral and 650 in gear. I put in new spark plugs and the idle picked up to 1200 in neutral i tried adjusting the idle with the idle screw and the barrel wheel on the throttle cable and i could only get it to drop around a 100rpms. Timing is set at 8 degrees does anybody have any ideas on what else i could do to get the rpms down.
